RandomSrf Esiste un modo per recuperare questo script ?
'RandomSrf - creates a randomized copy of a surface
'Jess Maertterer - develop design - info@de-de.de - � 17.06.2002
public ddx,ddy,ddz
Sub RandomSrf
Rhino.Command “PtOff”
Dim ma
ma=Rhino.GetObjectId("Select surface to randomize ",8)
If Not IsNull(ma) Then
Rhino.SetObjectSelect ma,vbtrue
If Not Rhino.IsSurface(ma) Then
MsgBox “Selected surface is part of a polysurface”
ma=vbnull
End If
End If
If Not Vartype(ma)=VBstring then exit sub
Rhino.SelectAllObjects vbfalse
ma=Rhino.CopyObject (ma)
Dim C0, CU, I0
C0=Rhino.GetSurfacePointCount(CStr(ma))
CU=C0
If Rhino.IsSurfaceSingular (ma) Then
sxp ma
For I0=0 To C0(0)
Rhino.Command “NextU”
Next
for I0=0 To C0(1)
Rhino.command “NextV”
Next
rhino.Command “Smooth Enter”
rhino.Command “PtOff”
End if
Dim CO, M1, CurrentLocale
Rhino.Command “ExtractControlPolygon”
M1=Rhino.GetLastObjectID
CurrentLocale = SetLocale(“en-us”)
CO=Rhino.GetMeshVertices(M1)
Rhino.DeleteObject M1
Dim uc, vc
If IsArray(CO) Then
M1=UBound(CO, 2)
Else
Exit Sub
End If
For I0=1 to M1
If CO(0,0)=CO(0,I0) And CO(1,0)=CO(1,I0) And CO(2,0)=CO(2,I0) Then
If I0 < C0(0) ANd C0(0)=CU(0) Then C0(0)=I0 +1 : uc=vbtrue
If I0 > C0(0) and C0(1)=CU(1) Then C0(1)=((M1 + 1) / (C0(0))) : vc=vbtrue
End If
next
Dim O0, l1, RF, S1,mx,my,mz
If Not Vartype(ddx)=vbdouble then ddx=1
If Not Vartype(ddy)=vbdouble then ddy=1
If Not Vartype(ddz)=vbdouble then ddz=1
ddx=Rhino.GetReal (“max X movement � “,ddx)
ddy=Rhino.GetReal (“max Y movement � “,ddy)
ddz=Rhino.GetReal (“max Z movement � “,ddz)
If uc or vc then
uid ma, CO
else
iud ma,C0
end If
Rhino.Command “SetRedrawOff”
For O0=0 To (C0(1)-1)
For l1=0 To (C0(0)-1)
mx=(rnd-0.5)*ddx * 2
my=(rnd-0.5)*ddy * 2
mz=(rnd-0.5)*ddz * 2
If Not ((l1=C0(0)-1) and uc) then
if not ((O0=C0(1)-1) and vc) then
S1=“Move 0,0,0 “&mx&”,”&my&”,”&mz
Rhino.Command S1
End If
End If
If l1 < (C0(0)-1) then Rhino.Command “NextU”
Next
Rhino.Command “NextV”
If Not uc Then
For l1=0 To C0(0)-2
Rhino.Command “PrevU”
Next
ENd If
Next
SetLocale(CurrentLocale)
Rhino.Command “SetRedrawOn”
Rhino.Command “ptoff”
Rhino.Command “SelLast”
End Sub
RandomSrf
Function sxp (srf)
Rhino.SetObjectSelect srf,vbtrue
Rhino.Command “PtOn”
Rhino.Command “InvertPt”
End Function
Function iud(srf, C0)
Dim I0
sxp (srf)
For I0=2 to C0(0)
Next
for I0=2 to C0(1)
Rhino.Command “PrevV”
Next
End Function
Function uid(srf, t1)
Dim tx,ty,tz, tl
tx=t1(0,0)
ty=t1(1,0)
tz=t1(2,0)
tl=“PlaceTarget w”&tx&”,”&ty&”,”&tz
Rhino.Command tl
Rhino.Command “CPlaneToView”
Rhino.Command “SelWindow -0.001,-0.001 0.001,0.001”
Rhino.Command “CplanePrev”
Rhino.Command “ZoomPrev”
End Function
Non capisco cosa intendi esattamente, ma credo che quello script tu lo possa trovare qui:
http://www.rhino3.de/_develop/v2_vbscript/improve_srf/index.shtml
THE SCRIPT NOT RUN ARE ABLE TO REPAIR?
if this paguina got the script!
but it does not work
I wanted to do was work rhino 3
EL sceneggiatura, no funciona en rinoceronte 5
My suggestion is to ask the script’s author: Jess Maertterer
You can just post on https://discourse.mcneel.com/
and mention @Jess
