Buongiorno
nell’inserire i vincoli ricevo il seguente messaggio d’errore “1. Solution exception:Could not find node at (0/0/1) where support index 0 is attached.”
Inoltre riscontro anche l’errore “1. There is 1 rigid body mode in the system. This means some parts can move freely without causing deformation.
Try to use the ‘Eigen Modes’-component and activate the display of local coordinate axes: The first eigen-mode will be the rigid body motion.
If this does not help, check whether you have a pinned support directly attached to a hinge. A hinge introduces an extra node which may cause the problem.
When analyzing a flat shell structure one has to lock the rotation perpendicular to the plate in at least one node.”
Allego file per valutare la situazione
Pattern parametrico.gh (134,3 KB)
