Dear McNeel,
how can I apply any kind of graphic around a surface?
In my file I have modeled a solid around which I would like to create continuous extruded designs, which I will then subtract using a Boolean command.
If I use the UnrollSrf command, unfortunately it generates a surface made of multiple parts, so the FlowAlongSrf command does not work correctly either.
I should mention that I am not interested in the top and bottom surfaces: the extruded graphic only needs to wrap around the solid.
How can I solve this problem?
Thank you.
