Viewport nere
salve a tutti, ho già seguito diverse discussioni qui sul forum riguardanti questo problema ma le soluzioni proposte in altri casi non sono servite, in seguito ad un aggiornamento windows le view sono completamente nere, se invece apro un file precedentemente salvato mi fa utilizzare normalmente la view rimasta come ultimo salvataggio, senza poter quindi dividere lo schermo nelle classiche 4 view di Rhino.
system info:
Rhino 7 SR37 2024-4-16 (Rhino 7, 7.37.24107.15001, Git hash:master @ d2e42f70b9d3aa58f6053e2998a0db2abcd7555b)
License type: Commercial, build 2024-04-16
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 Ti (NVidia) Memory: 8GB, Driver date: 8-14-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.94
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-14-2024
Driver Version: 32.0.15.6094
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\Utente\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22290.1357
C:\Users\Utente\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2019.11.5.949\Lumion\Rhino 6.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rendering di Rhino” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.37.24107.15001
C:\Users\Utente\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.37.24107.15001
Ciao.
Andiamo con ordine:
Vai nel menu Opzioni → Plugin e disattiva levando il segno di spunta, tutti i plugin non nativi di Rhino: Enscape, Lumion, V-Ray
Nel menu Opzioni → Viste → OpenGL disattiva GPU Tassellation.
Ti chiederei di allegare la schermata di quando avvii Rhino 7 normalmente.
ho disattivato i plugin e la gpu tasselation ma il prolema persiste, ti allego la schermata di apertura di rhino.
ps. scusami, non ti ho salutato, ti ringrazio per l’aiuto tempestivo
No problem!
SE fai File, nuovo e parti da un template fa lo stesso?
Hai provato a riparare l’installazione da pannello di controllo Rhino 7 tasto destro ripara.
Eventualmente se installi TeamViewer posso dare un occhio alla macchina. Nel caso mandami in privato il tuo telefono per comunicare durante il supporto.
provo con il ripara e ti aggiorno, comunque mi da lo stesso problema in qualsiasi modo apra rhino, in caso il ripara non funziona scarico teamviewer e magari proviamo in quel modo se per te non è un problema.
Non è un problema!
A beneficio di chi avesse un problema analogo:
Abbiamo avviato in Safe Mode e le viste erano normali. (Sceda video disabilitata)
Al successivo avvio normale, quindi caricando la scheda video, siamo tornati alla situazione normale.
Riccardo mi diceva di improvvisi backout avviando PS (istantanei). Non da escluder un problema hardware.
So far, so good.
