Problemi salvataggio Rhino8
Ciao a tutti, ho qualche problema ultimamente nel salvataggio dei file. Eppure sono l’unico ad averli aperti e a lavorarci. Questo problema dura da 3-4 aggiornamenti di rhino8. Gli aggiornamenti sono impostati su service release candidate. Ah, i file sono salvati su un server aziendale. Succede anche a qualcun altro?
Allego SystemInfo e gli screenshot dei messaggi di rhino.
Rhino 8 SR5 2024-2-20 (Rhino 8, 8.5.24051.15001, Git hash:master @ 8ad7c99e58df0a8c09e572ba1ae2b52a6f429060)
License type: Commerciale, build 2024-02-20
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.16
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro K4200 (NVidia) Memory: 4GB, Driver date: 10-10-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 474.64
- Secondary monitor attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-10-2023
Driver Version: 30.0.14.7464
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\federico\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\RPC\0.0.12\RPC.rhp “RPC”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\ColorPicker (336da4ab-03d3-42ca-b1fb-313bfd4c1157)\2019.2.15.811\ColorPicker.rhp “ColorPicker”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24051.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24051.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24051.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24051.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24051.15001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.5.24051.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24051.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24051.15001
SnapCrab_NoName_2024-2-22_17-9-53_No-00
SnapCrab_NoName_2024-2-22_17-9-43_No-00
Avviare Rhino e dal menu Opzioni scegliere avanzate.
Selezionare la chiave: Rhino.Options.FileSettings.WriteLocalTempFileWhenSaving e settare il valore su “False”.
Riavviare Rhino e provare il salvataggio in una posizione di rete.
Ciao Giuseppe, grazie della risposta. Ho provato ma non cambia niente purtroppo.
Ciao Federico,
Non è solo Rhino ad essere aggiornato ma anche Windows in continuazione. Non è che per caso sono cambiati i permessi e non ti permette di salvare?. Immagino che localmente non hai problemi.
Se è un server nas sei sicuro che il firmware sia aggiornato?
Con il flag tolto ovvero FALSE sulla voce che ti avevo indicato non abbiamo altri casi di mancato salvataggio. O almeno non ne ho visti.
Ciao Giuseppe, il problema non è salvare file sul server perchè solitamente per aggirare il problema faccio dei salvataggi incrementali e poi con quelli posso lavorarci e salvarci sopra fino a che non chiudo il disegno e lo riapro. Allora solitamente si ripresenta il problema e quindi faccio un nuovo salvataggio incrementale e via di questo passo. Inoltre i miei colleghi che ancora usano rhino7 non hanno di questi problemi. Anche un mio collega che non ha aggiornato rhino8 (ha ancora la 8.3) non ha di questi problemi.
Federico, il salvataggio incrementale è una buona idea ma in questo caso salva un file con nome diverso e non ha niente a che vedere con il problema in oggetto che - se non sbaglio - è salvare un file che ha un suo nome presente su server. Comando Save. Questo comando usa una meccanica di salvataggio che richiede di rinominare un file…etc…
Per caso hai anche Rhino 7 installato su quella macchina?
Ho controllato il bugtracker per vedere se ci sono state modifiche legate a bug sul sistema IO (save) ma non vedo cambiamenti.
Nel caso posso vedere la tua macchina con TeamViewer. Scaricalo (gratuito) e installalo. Tieni pronto ID e password e in privato mandami un contatto telefonico così ci organizziamo se vuoi.
Ciao Giuseppe, siccome ho parlato con chi ci gestisce il server e ci ha aggiunto dei permessi ma la cosa si presenta ancora e non sistematicamente e la cosa non mi è chiara sono andato a vedermi il forum inglese e mi sono imbattuto in questa discussione che sembra sia legata al mio caso.
