Rhino 7 macbook pro M2 Max
Buongiorno a tutti, sto testando la versione di valutazione di Rhino7 su un Macbook pro M2 Max con non poche difficoltà. Sostanzialmente il file su cui sto lavorando si apre ma qualsiasi operazione risulta lentissima. Pensavo fosse una problema del file ma ho provato ad aprirlo sul vecchio Macbook pro (mid.2014) in cui c’è Rhino 5 e in quel caso riesco a muovermi senza problemi.
Digitando _SystemInfo questo è quello che esce:
Rhino 7 SR28 2023-2-27 (Rhino 7, 7.28.23058.03002, Git hash:master @ 4ffc5d7156fbccf2a5d9fcc80e522b3851bc7f6c)
License type: Evaluation, build 2023-02-27
License details: Stand-Alone
Expires on: 2023-06-18
Apple macOS Versione 13.2.1 (Build 22D68) (Physical RAM: 32Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: Mac14,5
Language: it-IT (MacOS default)
Apple M2 Max (OpenGL ver:4.1 Metal - 83)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 21845 MB
Graphics: Apple M2 Max
Displays: Unknown (255dpi 2x)
Graphics processors
Apple M2 Max
Color LCD (1512 x 982 @ 120.00Hz)
USB devices
PixArt: USB Optical Mouse
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCore.dylib
/usr/lib/swift/libswiftCoreFoundation.dylib
/usr/lib/swift/libswiftDarwin.dylib
/usr/lib/swift/libswiftDispatch.dylib
/usr/lib/swift/libswiftIOKit.dylib
/usr/lib/swift/libswiftObjectiveC.dylib
/usr/lib/swift/libswiftXPC.dylib
/usr/lib/swift/libswift_Concurrency.dylib
/usr/lib/swift/libswift_StringProcessing.dylib
/usr/lib/swift/libswiftos.dylib
/usr/lib/swift/libswift_RegexParser.dylib
/usr/lib/swift/libswiftOSLog.dylib
/usr/lib/swift/libswiftAVFoundation.dylib
/usr/lib/swift/libswiftCoreAudio.dylib
/usr/lib/swift/libswiftCoreLocation.dylib
/usr/lib/swift/libswiftCoreMIDI.dylib
/usr/lib/swift/libswiftCoreMedia.dylib
/usr/lib/swift/libswiftMetal.dylib
/usr/lib/swift/libswiftQuartzCore.dylib
/usr/lib/swift/libswiftUniformTypeIdentifiers.dylib
/usr/lib/swift/libswiftsimd.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftCryptoTokenKit.dylib
/usr/lib/swift/libswiftCoreGraphics.dylib
/usr/lib/swift/libswiftCompression.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftIntents.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCoreImage.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftAccelerate.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftDemangle.dylib
/usr/lib/swift/libswiftSystem.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftRegexBuilder.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/log/liblog_network.dylib
/Users/michelapellegrini/Library/Application Support/McNeel/Rhinoceros/packages/7.0/AMDDenoiser/0.5.3/AMDDenoiser.Mac.rhp “AMDDenoiser.Mac” 1.0.0.0
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.28.23058.3002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.28.23058.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.28.23058.3002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.28.23058.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.28.23058.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.28.23058.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.28.23058.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.28.23058.3002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.28.23058.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.28.23058.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.28.23058.3002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.28.23058.1002
Grazie in anticipo!
Ciao Michela,
In breve la situazione:
Quando abbiamo sviluppato Rhino 7 i processori M1 non esistevano e non esistevano strumenti di sviluppo rilasciati da Apple.
Quando sono stati messi in commercio gli M1, i relativi strumenti hanno seguito un rilascio molto con il contagocce. Il risultato è che Rhino 7 Mac su M1 e successivi gira con un interprete (Rosetta2) e questo diventa particolarmente ponderoso per la gestione della scheda grafica che ha la sua struttura base su OpenGL. Da quando è stato possibile lavorare direttamente con Metal per gestire la scheda, abbiamo iniziato a lavorarci ma gli effetti si vedranno con Rhino 8. Di cui c’è una versione WIP accessibile ai possessori di Rhino 7.
Ah ok, tutto chiaro grazie!
Scelta coraggiosa, per certi versi.
Non che a Apple manchi carattere.
Di questo ne pagano il prezzo gli utenti, IMHO. :innocent:
