Spessori linee in fase di stampa
Ciao, ho un problema con le stampe, ovvero che nonostante abbia impostato la larghezza delle varia curve nei vari livelli e impostato la larghezza di stampa su “per livello”,quando poi vado a stampare gli spessori risultano tutti uguali.
Avvia Rhino e sulla riga di comando digita: _SystemInfo (invio).
Il comando produrrà un testo che ti chiederei di allegare.
Rhino 7 SR4 2021-3-8 (Rhino 7, 7.4.21067.13002, Git hash:master @ ed629035202f07e8b84a3ee211479ca20bb81b73)
License type: Non definito, build 2021-03-08
License details: Stand-Alone
Apple Intel 64-bit macOS Versione 14.4.1 (Build 23E224) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro17,1
Language: it-IT (MacOS default)
Apple M1 (OpenGL ver:4.1 Metal - 88)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 10922 MB
Graphics: Apple M1
Displays: Unknown (255dpi 2x)
Graphics processors
Apple M1
Color LCD (1440 x 900 @ 60.00Hz)
USB devices
Newmen Tech.,LTD: 2.4G Wireless Mouse
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCore.dylib
/usr/lib/swift/libswiftCoreFoundation.dylib
/usr/lib/swift/libswiftCoreGraphics.dylib
/usr/lib/swift/libswiftCoreImage.dylib
/usr/lib/swift/libswiftDarwin.dylib
/usr/lib/swift/libswiftDispatch.dylib
/usr/lib/swift/libswiftIOKit.dylib
/usr/lib/swift/libswiftMetal.dylib
/usr/lib/swift/libswiftOSLog.dylib
/usr/lib/swift/libswiftObjectiveC.dylib
/usr/lib/swift/libswiftQuartzCore.dylib
/usr/lib/swift/libswiftUniformTypeIdentifiers.dylib
/usr/lib/swift/libswiftXPC.dylib
/usr/lib/swift/libswift_Concurrency.dylib
/usr/lib/swift/libswiftos.dylib
/usr/lib/swift/libswiftsimd.dylib
/usr/lib/swift/libswift_StringProcessing.dylib
/usr/lib/swift/libswift_RegexParser.dylib
/usr/lib/swift/libswiftCryptoTokenKit.dylib
/usr/lib/swift/libswiftAVFoundation.dylib
/usr/lib/swift/libswiftCoreAudio.dylib
/usr/lib/swift/libswiftCoreLocation.dylib
/usr/lib/swift/libswiftCoreMIDI.dylib
/usr/lib/swift/libswiftCoreMedia.dylib
/usr/lib/swift/libswiftCompression.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftIntents.dylib
/usr/lib/swift/libswiftAccelerate.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftRegexBuilder.dylib
/usr/lib/swift/libswiftDemangle.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftSystem.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/flaviasantangelo/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino6.rhp/DatasmithFacadeCSharp.dylib
/Users/flaviasantangelo/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino6.rhp/libtbb.dylib
/Users/flaviasantangelo/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino6.rhp/libtbbmalloc.dylib
/Users/flaviasantangelo/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp/DatasmithFacadeCSharp.dylib
/Users/flaviasantangelo/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino6.rhp “Datasmith Exporter” 5.3.2.0
/Library/ChaosGroup/Enscape/Enscape.Rhino.Plugin/Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.23338.1601
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.4.21067.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.4.21067.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.4.21067.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.4.21067.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.4.21067.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.4.21067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.4.21067.13002
Stai usando la service release 4 di Rhino 7.
Siamo alla service release 37…
Devi sicuramente aggiornare Rhino 7!
