Scheda video RHINO8
Ciao ,
ho un problema con una altro PC .
Nella visualizzazione ombreggiata la rotazione non é fluida e va a scatti.
Scheda: NVIDIA RTX 3500 driver aggiornati.
Qui sotto il system info:
Rhino 8 SR15 2025-1-19 (Rhino 8, 8.15.25019.13001, Git hash:master @ 74164bdf5469c2f269746857c54b8c44b74c7b24)
License type: Commercial, build 2025-01-19
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: LAPTOP - Plugged in [100% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 5-12-2024 (M-D-Y).
> Integrated graphics device with 4 adapter port(s)
Primary OpenGL: NVIDIA RTX 3500 Ada Generation Laptop GPU (NVidia) Memory: 12GB, Driver date: 1-26-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.16
> Integrated accelerated graphics device with 4 adapter port(s)
- Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-26-2025
Driver Version: 32.0.15.7216
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “StrumentiDiAnimazione”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rendering di Rhino” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Motore di rendering di Rhino versione precedente”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.15.25019.13001
Grazie Mille
Ciao , a mè capita delle volte che scatta , nel mio caso sono i driver del mouse 3D che danno i numeri mi accorgo perchè scompare la barra 3d Connexion, esco ricarico Menu Mouse poi funziona bene.
Ciao Fulvio,
Aggiorna a Rhino 8.16
Disattiva i plugin non nativi.
Un solo monitor collegato e poi verifica se il problema persiste.
Buongiorno,
vi aggiorno :
abbiamo aggiornato la versione come richiesto (di seguito il system info)
dopo l’aggiornamento, testato Rhino, sia con monitor collegato (tramite dock originale Dell con ultimo Firmware disponibile), sia solo con laptop (dock scollegata), e tutti i plugin erano disattivati, ma purtroppo il problema persiste.
Rhino 8 SR16 2025-2-11 (Rhino 8, 8.16.25042.13001, Git hash:master @ d0f731de6fe2c5fdcad78ad80faf154307815f18)
License type: Commercial, build 2025-02-11
.NET 7.0.20
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “ProcessoreInattivo”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rendering di Rhino” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.16.25042.13001
Fulvio, organizziamoci in modo pa poter fare un TeamViewer con questa macchina. Nel caso mi chiami.
Per me il problema è questo. Primary display deve essere solo la Nvidia rtx.
ok grazie facciamo delle prove
ok faccio una prova a mettere primary display Nvidia e poi vediamo
