Hi Everyone,
there is a way please to create all the surfaces of the steps from the curves in one time ?
Thank you in advance
stairs.gh (21,4 KB)
Welcome Tarik.
NURBS Surfaces (Srfs) are 4 sided topologies.
Looking at your model:
Each step (srf) has one shared edge where vertical and horizontal meet. You can not just window pick all the curves and call a surfacing command for all of them at once. Rhino can not understand how to sort the curves out .
A possible solution:
(1) Join the outer “stepping” curves into one composite curve. Same for the opposite side.
(2) Loft the composite curves.
Thanks a lot for your response. I resoleved with DUPBORDER command because I had already the geometry.
