Problema con il pannello Proprietà
Ogni volta che provo ad aprire il pannello Proprietà il programma si blocca e si chiude, sia cliccando sull’icona che cercando il comando dal pannello. Ho provato a reinstallare il programma, riavviare il computer… ma non cambia la situazione. Ho scaricato anche l’ultimo aggiornamento ma non è cambiato niente. Qualcuno sa aiutarmi?
Rhino 8 SR29 2026-3-4 (Rhino 8, 8.29.26063.11002, Git hash:master @ bbd126f84fcdaf7a974615b7c9f4f8667571c147)
License type: Evaluation, build 2026-03-04
License details: Cloud Zoo
Expires on: 2026-04-05
Apple macOS Versione 26.2 (Build 25C56) (Physical RAM: 18GB)
Mac Model Identifier: Mac15,7
Language: it-IT (MacOS default)
.NET 8.0.14
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M3 Pro
Color LCD (1728 x 1117 @ 120.00Hz)
GPU Vendor: Apple
USB devices
MOSART Semi.: 2.4G Wireless Mouse
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCore.dylib
/usr/lib/swift/libswiftObjectiveC.dylib
/usr/lib/swift/libswiftCoreFoundation.dylib
/usr/lib/swift/libswiftDarwin.dylib
/usr/lib/swift/libswiftDispatch.dylib
/usr/lib/swift/libswiftIOKit.dylib
/usr/lib/swift/libswiftSystem.dylib
/usr/lib/swift/libswiftXPC.dylib
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_Concurrency.dylib
/usr/lib/swift/libswift_DarwinFoundation1.dylib
/usr/lib/swift/libswift_StringProcessing.dylib
/usr/lib/swift/libswiftos.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftOSLog.dylib
/usr/lib/swift/libswiftsimd.dylib
/usr/lib/swift/libswift_RegexParser.dylib
/usr/lib/swift/libswiftMetal.dylib
/usr/lib/swift/libswiftQuartzCore.dylib
/usr/lib/swift/libswiftUniformTypeIdentifiers.dylib
/usr/lib/swift/libswiftAccelerate.dylib
/usr/lib/swift/libswiftCoreImage.dylib
/usr/lib/swift/libswiftCoreAudio.dylib
/usr/lib/swift/libswiftCoreMIDI.dylib
/usr/lib/swift/libswift_DarwinFoundation2.dylib
/usr/lib/swift/libswift_DarwinFoundation3.dylib
/usr/lib/swift/libswiftCompression.dylib
/usr/lib/swift/libswiftCoreLocation.dylib
/usr/lib/swift/libswiftRegexBuilder.dylib
/usr/lib/swift/libswiftCoreMedia.dylib
/usr/lib/swift/libswiftAVFoundation.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftCoreGraphics.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswiftIntents.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftCoreMediaIO.dylib
/usr/lib/swift/libswiftCallKit.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/updaters/libAppleTconUARPUpdater.dylib
/usr/lib/updaters/libT200Updater.dylib
/usr/lib/swift/libswiftDemangle.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_glTF.rhp “Import glTF” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ShrinkWrap.rhp “ShrinkWrap” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_glTF.rhp “Export glTF” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rendering di Rhino” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/PlugIns/export_SKP.rhp “Esportazione SketchUp” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_UDO.rhp “Esportazione Moray” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_RAW.rhp “Importazione Raw Triangle” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_USD.rhp “Export USD” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_E57.rhp “Importazione E57” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_VRML.rhp “Importazione VRML” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “StrumentiDiAnimazione” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_modelio_macos.rhp “Model IO Import” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_WAMIT.rhp “Importazione WAMIT” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/NamedPositions.rhp “Posizione con nome” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_SKP.rhp “Importazione SketchUp” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_RAW.rhp “Esportazione Raw Triangles” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/MPlane.rhp “PianoM” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_XGL.rhp “Esportazione XGL” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Motore di rendering di Rhino versione precedente” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_CD.rhp “Esportazione Cult3D” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_LWO.rhp “Esportazione Lightwave” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_SLC.rhp “Esportazione SLC” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_STEP.rhp “Esportazione STEP” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_WAMIT.rhp “Esportazione WAMIT” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_SLC.rhp “Importazione SLC” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_OFF.rhp “Importazione OFF” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Squish.rhp “Appiattisci” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_X_T.rhp “Esportazione Parasolid” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoBonusTools.rhp “Bonus Tool di Rhino” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoLabsTools.rhp “Labs Tools di Rhino” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_M.rhp “Import_M” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_X.rhp “Importazione X” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_IGES.rhp “Plug-in di importazione IGES” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_AI.rhp “Esportazione Adobe Illustrator” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_LWO.rhp “Importazione Lightwave” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_SAT.rhp “Esportazione ACIS” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_CSV.rhp “Esportazione valore separato da virgola” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_PDF.rhp “LettorePDF” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_STL.rhp “Esportazione STL” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_VDA.rhp “Importazione VDA” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_STEP.rhp “Importazione STEP” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_FBX.rhp “Esporta_FBX” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_SolidWorks.rhp “Importazione SolidWorks” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_STL.rhp “Importazione STL” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_RIB.rhp “Esportazione Renderman” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_FBX.rhp “Importazione_FBX” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_Points.rhp “Esportazione punti” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_VDA.rhp “Esportazione VDA” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_X.rhp “Esportazione X” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/CreaseAngle.rhp “AngoloDiPiegatura” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_3DS.rhp “Esportazione in 3D Studio” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_PLY.rhp “PLY - Importazione formato file poligonale” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/MeshTools.rhp “StrumentiMesh” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_Points.rhp “Importazione punti” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/MeshFromPoints.rhp “MeshDaPunti” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_VRML.rhp “Esportazione VRML/X3D” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_GTS.rhp “Importazione GTS Triangle” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “StrumentiSolidi” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_GTS.rhp “Esportazione GTS” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_POV.rhp “Esportazione POV-Ray” 8.29.26063.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.29.26063.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.29.26063.11002
ciao @Aurora e benvenuta,
giusto un tentativo da fare al volo:
hai gia’ provato a far partire Rhino in modalità sicura (Safe Mode)
Start > Programmi > Rhinoceros > Rhino in modalità sicura.
grazie, ha funzionato! sai darmi una spiegazione del perché?
magari dei plugins che vanno in conflitto creando il problema,
Rhino in modalita’ sicura (Safe Mode) appunto non li carica.
anche re-installando Rhino magari succede che i plugins rimangono
comunque nella loro cartella di destinazione non vengono eliminati
e quindi anche la nuova installazione di Rhino se li trova caricati.
ps se cosi’ fosse, bisognerebbe capire quale plugin crea il problema. . .
Ciao Aurora,
come ha già spiegato il buon Salvio, la modalità sicura di Rhino non carica i plug-in ma, oltre a quello, non attiva nemmeno l’accelerazione video 3D (almeno, questo il comportamento su windows; su mac dovrebbe essere lo stesso ma non lo utilizzo e quindi metto le mani avanti).
Vedo che stai utilizzando una versione Demo, hai per caso installato anche altre estensioni o plugin di prova (che magari hai disinstallato)?
Sicuramente usare Rhino in safe mode non è una soluzione a lungo termine (il programma funziona “azzoppato”), serve principalmente per identificare i problemi di incompatibilità.
