Problema "server occupato"
Buongiorno,
Piacere, sono Mattia; è tanto che vi leggo ma non mi espongo mai :stuck_out_tongue:
Vi lascio con un problemino che sto avendo con rhino 8: quando seleziono degli oggetti ogni tot rhino si blocca per un attimo e poi esce questo messaggio:
è una cosa che purtroppo capita frequentemente…
lascio anche il system info:
Rhino 8 SR7 2024-5-13 (Rhino 8, 8.7.24134.03001, Git hash:master @ 215e2aecc0d8fbc7e0448df10b8ce818dac77137)
License type: Commercial, build 2024-05-13
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1650 (NVidia) Memory: 4GB, Driver date: 6-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.23
- Secondary monitor attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-8-2023
Driver Version: 31.0.15.3623
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\Utente\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\S3D_RhinoDiamond\8.240430.7\S3D_RhinoDiamondToolbar.rhp “S3D_RhinoDiamondToolbar” 1.0.0.0
C:\Users\Utente\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Smart3dInstaller\8.240503.1\Smart3dInstaller.rhp “Smart3dInstaller” 8.24.423.1
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Grasshopper_Gold_Tools\1.0\Grasshopper_Gold_Tools.rhp “Grasshopper_Gold_Tools” 1.0.0.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\ToolPanel\1.0\ToolPanelV2.rhp “ToolPanelV2” 2.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.7.24134.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rendering di Rhino” 8.7.24134.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Motore di rendering di Rhino versione precedente”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.7.24134.3001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.7.24134.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.7.24134.3001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.7.24134.3001
Ciao Mattia!
Esponiti senza timore.
Vorrei chiederti di fare una prova senza utilizzare plugin esterni a Rhino.
Digita sulla riga di comando: _PluginManager e invio.
Nella parte destra in alto della finestra, nel menu a tendina puoi selezionare tutti i plugin non nativi di Rhino. Leva il segno di spunta a tutti loro.
Conferma, chiudi Rhino e avvialo nuovamente. Fai delle prove. Hai sempre lo stesso problema?
Altra possibilità:
Richiesta di verifica aggiornamenti da parte di Rhino che non riesce a passare.
Sempre nelle Opzioni, prova a disabilitare la ricerca aggiornamenti. Non è una soluzione definitiva ma è una prova molto utile.
Grazie per la risposta Giuseppe!
Confermo che disattivando i plug-in non nativi di rhino non mi esce il messaggio.
Quindi sostanzialmente c’è un plug-in di terze parti che da problemi? che si fa?
Presto detto:
…si individua con esattezza quale è il “colpevole” abilitandone uno alla volta.
Poi si contatta chi lo sviluppa spiegando tutta la storia e tutte le prove fatte. Possibilmente fornendo un file con il quale il problema si manifesta in maniera replicabile.
Questo dovrebbe aiutare a trovare una soluzione.
Grazie mille! ti aggiorno :slight_smile:
